1- Version: Latest version of Lumia and Latest firmware of YEELight app / strip
4- Screenshot if possible: None available currently.
I have two YEELights both are on the same wifi network. the one is a light bulb and connects just fine to Lumia and YEELight App and works great. the other is the S1 light strip. It connects to the App but i can not find it in lumia. From the app i can control the strip just fine. the LAN control is turned on. Not sure what the issue. Both on the same network. My computer is hardwired.
here is what i tried:
- multiple times to delete the device and re-add it.
- i assigned the device a static ip from my router and re-added it. It gave it the right IP but lumia still wont find it
- i tried to search for the device from my computer while hard wired and while on the same wifi network. Both times lumia did not find the device.
i dont know what else to try. does anyone have an S1 yeelight strip that is connected and having luck with it?
Here is the exact link of the one i have:
Any help would be GREATLY appreciated!
