1- Version: 5.3.2
2- System: Windows and Mac
4- Screenshot if possible: N/A
want to Connect WLEDs // WLEDs are in the same Network and are reachable via IP.
after typing in the IP manually and adding the light it looks good but if you proceding with Next
and you reopen the WLED Connection Window there are no lights shown.
Best regards the-H-man
Hi, sorry for the late reply. Does the problem still exist?
I was having a similar issue and fixed it, in case anyone else comes across this.
Update WLED on your microcontroller to the newest beta, then in the settings disable WiFi sleep.
After I did those two things, it’s been working pretty much flawlessly.
Thanks for letting the others know… also with Version 5.5-Beta there have been some fixes
