I can’t add widgets to the overlay from the site www.donationalerts.com It says the site www.donationalerts.com is blocked.
I am not sure what you try to do? How do you try to add a widget?
in overlay
Yeah, that might not work as some websites avoid having other apps using their URLs. You can’t use this on the Lumia Overlays
