1- Version: 5.5.1
Describe the issue:
I have been using lumia stream for over a year with my Lifx lights. I have channel points set up to where viewers may use their earned points to select the lights to change to a certain color for 60 seconds. Recently the channel points function has not worked when a viewer selects the light color so I have to select it from OBS on my end through channel points and the lights will change. I know the lights are connected because they will flash for other notifications as well such as a new follower.
