1- Version: 6.1.1
5- Describe the issue: Trying to set up a theme with my philips hue scenes so my hue stream setup can be the default setup in lumia stream. After connecting the lights with the bridge. The Scene section is blank and will not show any of my scenes from my bridge
Hi, go to Connections → Hue and untick fast mode.
Fast mode is already unchecked
I have another user with the same problem… I will come back to you when I know what the problem is there. Maybe it will also fix yours
We found the issue and will fix it. On Friday will be a beta hotfix release…so if you want to try that turn on allow Beta Settings->General
This topic was automatically closed after 17 hours. New replies are no longer allowed.
