Stream Deck Integration: Cycles not working on Studio Animation
1- Version: 6.2.0
2- System: Windows/Mac
5- Describe the bug: Studio Animations only cycle 1 time no matter how many cycle numbers are input in the Stream Deck integration.
Thanks for reporting. That will be fixed. You can work around by creating a command and set the cycle there. Then use the command button for Stream Deck
