Sporadic MIDI Behaviour
I’m reporting this here because the bugs thread is locked currently for new topics.
I found with version 8.0.x and higher, it’s not sending the midi messages correctly.
It seems to stall when sending messages.
I would like to roll back to 7.5.4 for testing purposes but I need the installer to be able to rollback.
The changelog lists are there but not the install file(s).
Just to add more info, I did update to the latest 8.1 beta version and the same thing happens.
Hello,
I found the issue, they changed how Midi messaging works in SoundSwitch 2.9.
I have to send two messages to turn the color pads on/off via midi now vs before were I could send one to do the same thing.
Note On Velocity 1
Note Off Velocity 0
Sending those messages will turn the color pad on and sending them again will turn then off.
