1- Version: 6.2.0
4- Screenshot if possible – Not really screenshot-able
5- Describe the issue: This could simply be a documentation or id10T issue but I am calling out to an API for an application I use for my stream that I am attempting to integrate with LumiaStream’s bot. The command completes successfully it seems but, I can’t seem to find a way to return the ouput from the API to the chat bot.
Flow:
Chatbot receives command → Passes {{message}} and some other data to API → Event Occurs and API responds → Chatbot only gives it’s base output
I can’t get that response to be used as an output for the chatbot. I’m not sure if this is simply not possible right now and needs to be entered as a Request or if I am just not doing something correctly.
