No Smooth Transition with GIDERWEL Smart WiFi DreamColor
1- Version: 6.0.2
5- Describe the bug: Using Magic Home GIDERWEL Smart WiFi DreamColor and do not have smooth transition support. I have tried multiple things and using the Magic Home app I can do the smooth transitions so I know the product can support it. Using the premade Lumia Starter “Red Alert” My lights just turn on and off no fade and same is true for other customs and premades.
Hi,
our devs already are looking into Magic Home as it seems they made some changes. If everything works out transitions should work again with update 6.1. Unfortunately, we are always dependent on what options the manufacturer gives us.
