You most likely have dynamic default turned on. Turn it off by going to the Sidebar and pressing Default State. There you will see a checkbox that says Dynamic Default. Make sure this is off.
Colors, Lights Off, Scenes, and Themes are all valid dynamic defaults where as animations, reactions, and hypes are not.
Dynamic default will consider the last valid command triggered as the new default. That’s why when the command is triggered it stays as the new default.
