1- Version: 6.1.3
5- Describe the bug: I manage to connect my 4 govee lamps, they work for a few seconds, then remain frozen in one color and apart from putting a new API (which I have done at least 3 / 4 times) and it has the same problem , I think it’s because I have too many lamps connected at the same time, when I only had one lamp, it bugged less, and the more lamps I added, the more it was messing up, and the application tells me outright “check the connection of your govee lamps” I do not see where the problem comes from, I have already checked the whole forum but there is no solution to my problem.
Can you tell me where the problem comes from, and if there is a solution, please?
Cordially.
