I recently added a second set of Govee floodlights to my setup. I tried to connect them to Lumia Stream, but they do not show up in the connections for Govee… only the first set of lights is showing. Any suggestions?
Try it with a new API token
Yes, I tried that several times but thank you
Did you delete the connection in Lumia and tried connecting both together?
yes I did
If you could come to our discord I can look deeper into it… Lumia Stream
This topic was automatically closed after 13 hours. New replies are no longer allowed.
