I would like to see the option added in commands for a command specific default override. To further explain my idea, a command will finish and the lights will not reset to default. In some instances this can be very useful. How a command currently functions is if the default state is set to a specific color for example, a finished command will always set lights to that default color. With the new option activated, a command could be triggered, and once the command finishes, nothing else will happen. This could be particularly useful for automations and audio/video/image/chatbot only commands. They can run during other active commands without resetting any timers or overriding active commands.
