1- Version: 7.x
4- N/A
5- Describe the bug:
What I’m finding is every so often I have to delete and re-add the midi port to Lumia Stream and then refresh it on all my light commands and animations.
I used to happen between updates but last night it happened without updating. I had to delete the midi connection and re-add it.
Then re-assign the midi port to all the lights and animations. However, what I noticed is the port will change from 5 to 6 and other times default back to 5 other times.
