Magic Home Bulb (A19 bulb) support question
About to buy some new bulbs in a move to use lumiastream from my C by GE bulbs which weren’t… I am wondering if the magic home bulbs would work since I see the magic home LED strip controller is on the compatibility page, since it is used via the same app I figured I’d ask here.
Like these… https://www.amazon.com/dp/B093F7DC6L for instance are compatible with both magic home pro app system.
Hi, you can’t use the Magic Home bulbs yet.
For bulbs I can recommend Philips Hue or LIFX
