1- Version: 6.0.1 +6.0.2
2- System: Windows7
I tried to install lumia stream 6.0.1 and 6.0.2 on 3 different PC´s with Win7 (i can´t change to Win10/11 because need it for work).
The installation is no Problem. But nothing will run when i try to open it.
its the same problem like that from react_dnb: When I check task manager I see 4 instances running but no matter how long I wait the dashboard doesn’t open.
Unfortunately Windows 7 is not supported with newer versions of Lumia anymore. But you can still use it with Version 5.5.1
https://storage.lumiastream.com/updates/Lumia%20Stream%20Setup%205.5.1.exe
Thank you for helping. it is running.
next problems
OBS Studio shows no connection and cant connect the philips hue
i can press the Hue brigde button for over 5 seconds… nothing…
Well…I can’t tell you for OBS. They have a new version out.
For Hue you can try to connect them with WiFi…when you found them you can go back wired
This topic was automatically closed after 19 hours. New replies are no longer allowed.
