1- Version: 6.4.0/6.45 beta
3- Account:Premium
5- Describe the issue: I cannot connect my Broadlink RM4 Pro, it still states the device is locked even though it is unlocked.
Lumia Stream can find the RM4 and add it , so there is definitely something else at play. I have verified the device lock is turned off.
I’m wondering is there any logs I can check for Lumia Stream that will help me identify what the problem is?
I have successfully connected the unit to the wifi. I was able to configure the light I was trying to control. It learned the remote codes via the Broadlink phone app and functions normally.
I have other connectors working in Lumia stream over the network so I don’t believe this is a firewall/router issue. However, I’m still investigating this as well.
