How do I get Lumia to see my Alexa Smart Plug?
Ok, I am trying to get Lumia to see my Alexa Smart Plug. I have my lights plugged into this smart plug and have them turned on when someone uses bits to activate them. I can get Alexa to turn the lights on and off and I have Amazon/Alexa tied to the Lumia account but I’m not seeing the plug in either Lumia or the Lumia Alexa Skill. I’m so lost.
Thanks for any help!
Hi… Unfortunately, Alexa smart devices are not supported by Lumia Stream. Have a look at our list of supported smart device brands here: Lumia Stream - Your Community Illuminated
We would appreciate it if you drop your support request on our “ideas” site. We always try to integrate more (if possible) brands and devices. https://ideas.lumiastream.com/
