1- Version: Latest as of 11/14/21
As of today, LS will not trigger OBS sources or filters. Everything is connected, and everything works except the sources.
IE: Redeem a channel point to set source visible. It wont even work from within LS using test.
Any help would be greatly appreciated.
Worked before todays update
Version 5.4.0-beta. 10
TIA
Thank you for posting. The problem is reported already and the dev informed
I am sure there will be a fix soon.
I sure hope they fix soon. I run ALL channel points through LS and have so much time invested in all my lighting, sounds, filters, and sources. There is no way I would attempt to redo it now. This took months to build.
I appreciate the response.
Fingers crossed
Fixed with new update! Love it, THANK YOU LS
