Is there a way to setup default light states for individual lights? I have been using Lumia for a “flashbang” command and have the default state set to lights off so after I am flashed the light will turn off. I have added two new lights, but because of the default state they are turning off when I want them on. Is there a way to make the “flashbang” light turn off as a default state while my other lights stay on? No matter how I play with it, it ends up with my fb light always on which is something I don’t want because its distracting.
What lights are you using, and could you clarify what you mean by ‘fb light’?
I am using Lifx bulbs: a-19 for the flashbang=fb and two b10 lights for ceiling light.
Alright
Then create a scene with your 2 ceiling lights. This is what you set as idle state.
Set default state to lights off → enable idle state → put a delay of a second and set your scene (you probably can put the delay shorter. That’s something you must try to your convenience)
Then you build an animation for the flashbang. Because you need to tell Lumia that only that one light should flash.
This topic was automatically closed after 32 hours. New replies are no longer allowed.
