Copy more than one slot
Hi,
for making animations, which can be big sometimes it would be cool to select more than one slot to copy. So you can copy a whole block of same actions if you need. I.e. I make an animation fitting to a song snippet…a fast part and a slow part… but actually I would need the fast part for the end again. But Lumia puts the copied slot right next to the original. So I have to drag it aaaaaaallllll 20 slots down to place it scroll back up and do the same with the next
