1- Version: 5.3.2
So how do I set up the alerts variations, to play different variations when people are following me. The % frequency doesnt work when I press the “Only Variations” button. I want it to randomize which variation it uses everytime someone new follows me. That way it won’t be the TTS message playing over and over.
Could you please make a screenshot of 1) the follower alert settings (so the first thing you see when hitting alerts) and 2) settings of a variation, maybe two
There are different TTS messages that should be triggered. I want them to trigger randomly when people follow the channel. So it’s not the same message everytime.
Okay…I had a talk with the dev. I guess we both misunderstood the workflow of that random percentage
They dont stack… so you can never fill the 100% with variations. If you set 20% its very low and the chance is for every variation the same. Not like: I didnt hit red then it must be blue.
So if you want to use this random “gambling” variation you should have the base alert for the cases it doesnt hit the 20%. If you want to play around with only variations I would suggest to use higher values but there will stay the chance that just nothing happens.
I got your idea and we dont have that in Lumia yet what you actually try to do.
