1- Version: 6.0.1
2- System: Mac 11.6
5- Describe the issue: I am trying to setup control of DMX Color Changing lights through an Artnet wireless device. I have the Artnet device setup in Connections. I can find no help with adding the individual DMX fixtures connected to the Artnet device. How do I do this?
hi there
artnet is a very powerfull piece of kit
but its a little hard to explain it via here so would u be able to contact me on discord since its easyer to do it with pictures and text
best regards LJ Rens
Currently there is no way to add fixtures. It’s a planned feature. The only way you can control lights directly with ArtNet atm is to send dmx values per channel. It’s quite clunky, it’s like using an old preset board, but that is the only way atm. If on the other hand you have a controller that can take remote in, ArtNet, Midi, or OSC, then you can use that to trigger your cues from Lumia.
Until LumiaStream does ArtNet well, I’m going to use MIDI paired with loopMIDI and QLC+ to run the lights and send DMX via ArtNet. Lumia Stream will just handle the triggers.
