I have seen this feature used in other chat bots where regular chatters are greeted with custom messages. This would be nice if I could create a audio/light effect based on chatters/VIPs first message in the chat that day.
Wait for the next update
you can do that using chat match and custom javascript there is one specific for greeting in the code marketplace
- head to chat match then add match leave the dot as it is this means that it trigger this command based on what is typed on that field (dot . means any message)
- edit that command
- go to custom javascript at the top
- click code marketplace
- click community code then you’ll see “greeting users in stream”
- click use this code save and apply
- refresh your settings and you are good to go
you can disable the regular chatbot and set the command to nolight change if you want
have a great stream
